Consolidating audio in Cubase?
wx3
Hey,
I know this isn't the cubase fourm, but theres a lot of people in here right now and I need an answer before tomorrow morning.
I just recorded a tune at home in cubase, and tomorrow im going to bring it to the studio and mix it in pro tools.
I know in protools you can consolidate your audio to make all your edits into one long audio file.
As far as I can tell there's no easy way, without mixing down each track seperately, to do this in cubase?
Any one know how?
Thanks guys.
Which Cubase do you have? I have SX3 but no longer use it.. I'm a Sonar PE fan now.. But I can help you if you still need it
If I understand you correctly, set your left and right marker to where you want. Just make sure the entire audio part is whithin the markers. Solo the track you want to export and go to File, Export, Audio. Select where you want it saved, format, etc.
Hope this helps.
Kenny
Yeah, thats what I ended up doing. I was just trying to find a command that would do it to all your tracks at once. No luck though.
Thanks.
