Doowah
Okay, based on a ton of research on this site, I pulled the trigger and ordered an FMR RNP preamp and the FMR RNC compressor as the first new pieces of equipment for my current home studio project. (Got smoking deals on both, BTW. Only $125 for the RNC and $400 for the RNP, both units brand new, cashing in on holiday specials from one of the big online music stores!)
Next major purchases will be a Soundcraft M8 mixer and an audio interface (undecided on which one still). My typical newbie question concerns how to connect this gear up, focusing only on the hook-ups for recording at this point. The Soundcraft mixer will also be used for monitoring purposes, but I'm not concerned with that part of the equation just yet.
I'm thinking along the lines of something like this:
Microphone (or other source) into the appropriate input on the preamp (XLR or TRS or Hi-Z), with the compressor connected to the preamp via the insert jacks on the preamp. The part of this whole thing that I need help with is connecting the preamp output to the Soundcraft mixer and/or the audio interface. Since both of those subsequent units in the signal chain also have built-in preamps, do I connect the RNP's outputs into the line-level inputs of the mixer and/or audio interface, bypassing their subsequent (redundant) preamp sections?
Do I have this figured out correctly?
Am I correct in assuming that if I intend to only use the RNP as my preamp, then all other connections after the preamp should be at line-level? Or am I missing something here?
As always, thanks for the help, and I apologize if this is a dumb question.
