Ok I'm thinking of adding a compressor to my setup, so im able to compress before going into the soundcard. The obvious choice is the FMR RNC which everyone seems to talk about...
However, if im recording drums, can/should i use it to compress the overheads, or the kick and snare. Is it possible to compress to seperate parts of the kit ie the snare and kick, or would you need two compressors for this? I can only afford one at this time, so is it a worthwhile purchase? I'l be using it for vocals and guitars also.
cheers
cheers
