Component leads and PCBs
  • Thread starter Thread starter rmaier
rmaier
rmaier
What's the best way to accomodate larger component leads without damaging the board/ traces? I'm upgrading capacitors in a pair of Apex 460s and the Capacitor leads on the new parts are just a hair too big.:confused:
I've used steel wire or a drill bit that fits the existing hole. You put the bit in and rotate the end without turning the bit (and thus not removing material in a through hole). The idea is to expand the diameter of the hole.
A large needle would work too.
Regards, Ethan
Or just solder a small wire on the cap and then solder to the board.
If the PCB is a single sided PCB without plated through holes and the Pad is big enough you can make the hole bigger with a mini drill bit , otherwise just use a smaller gauge wire and solder one end to the PCB trace and the other to the component , you can also solder directly to the traces on the underside of the board but might need to scrape away a bit of solder mask .....
Cheers
