ericlingus
Hello i'm new to recording and need to isolate my amp when recording. My studio is just one room(my bedroom) with a small closet. The closet is where I put my amp. The closet is about 3' long and 2' wide and about 8 ' tall(there is a shelf that is about 6' high). I need to sound proof this closet the best I can with not a huge budget. I'm willing to spend a couple hundred dollars. That's all I can afford. Also, not only do I need to soundproof it(or as close to soundproofing as I can), but I need to treat it to that my miked amp sounds good. Right nwo it's too bassy. I'd also like to make this a vocal booth too. Of course I can only have it one or the other while recording. There is not enough room to fit both the amp and a person with mics. I have the amp on an amp stand about 2' high and slightly tilted back. Right now I stuffed a thick feather cushion thing that goes on a queen sized bed on the shelf and I put foam along the walls and a matt and carpet on the floor. I also put a thick sleeping bag up on the wall that the amp is facing and behind the amp. This helps a bit but obviously not enough. It also doesn't do much to treat the low frequencies. What can I do to treat this closet spending as little money as possible?
