J
justinchannell
I'm using a Vesta Fire MR10Pro 4 track and I was wondering what head cleaner to use. Should I use a cassette based cleaner on it or is there a liquid that I can put on a q-tip to clean with?
Cheaper is not always better !!NYMorningstar said:Welcome!
Go to the drug store and get yourself a bottle of 99% alcohol and use q-tips, it's a lot cheaper and will last longer. Don't leave the bottle open because it will absorb the moisture out of the air.
Also, don't try demagnetizing your heads, it's a waste of time, energy and your money.
Stealthtech said:
Pure alcohol may not be a good idea.
eyeslikefire said:
NYMorningstar said:
There's an old saying that if you can't dazzle them with brilliance then baffle them with bullshit. Telling you to demagnitize your recording heads is baffling you with bullshit.
Just think of it in simple terms. Let's say you degauss the head and remove all the so called residual magnetism that they say may or may not be there. As soon as you record it becomes a magnet again undoing what you just did. So... what's the point? There is none. It's a waste of time and energy and there is a chance of damaging the heads if you touch them with the degausser. Of course, if I'm selling degaussers I'm sure I could be real convincing you need one for the heads! IMHO
eyeslikefire said:Oh by the way,...
This a PDF from the department of Naval education.
http://www.advancement.cnet.navy.mil/products/web-pdf/tramans/bookchunks/14195_ch3.pdf
NYMorningstar said:
...snip
Give the capstan, pinch roller and tape guides a good cleaning and the should take care of the flutter
snip...
Wil Davis said:
BTW: Mr NYMorningstar - no offense meant, but I think your original comment about degaussing the heads being a waste of time, to be about as far from the truth as it could be. My experience has found the exact opposite to be true. Oh, I just noticed that we both have the same number of experience points - for what it's worth.![]()
Well we're all entitled to our opinions and until someone like yourself can explain to me why it's beneficial to demagnitize a magnet, I'm keeping mine.
