ido1957 said:
... the guitars on this new mix. It's almost like they've been re-amped (sp?). It makes the song rock a bit more......
Thanks, idol. That's what I was going for.
I actually just doubled it. I sent the original guitar to a bus at unity gain and set up a...oh, 37ms or so...delay to knock the fake second guitar slightly out of time with the first. Panned hard right and left with the fake guitar turned down slightly to make room for the real secondary guitar part. The send is post fader so I could control the volume of both tracks with one fader.
It usually better to just record a second guitar track- much more realistic- but this is an easy way to cheat if you don't have that option. Rami, this is how you start filling those 24 tracks- play all your guitar parts twice. Except the solos, unless you're really daring!
As for the rest of it, I EQ'd things more or less the same way Llarion did. By ear, listening to what needed to be brought out or turned down. I "reamped" (Amplitube) the bass figuring it had been recorded direct and the amp/speaker sim did a lot of the EQing for me. I didn't touch the guitars at all, though, with EQ or compression.
The drums, and a little bass, were also sent to a buss where they were *heavily* compressed with Pro Tool's BF76 plug set with all buttons in. Attack and release set so that the submix pumped and beathed in time with the song. Then the drum and bass sub was brought up to a few dB under unity. Voila- fat compressed drums with all their transients intact.
I added a faint delay for the solo and automated it a bit to emphasize certain parts- its should be fairly subtle. Panned the delay about 35 left and the solo about 35 right- same place the secondary guitar was. Theoretically the 2 parts would be played live by the same person so it seemed more realistic that way.
Lots of little volume atuomations going on. At key transitions the guitars are always coming up a little as soon as the vocals stop. Keeps it loud without just smashing the whole mix through a compressor. Vocal automation to bring quiet phrases up to compete with the loud guitars.
The lead vocal tracks ARE fairly heavilly compressed - the BF76 again - at 4:1. There is no threshold control on it, but the thresh is the equivalent of about -30. That's part of the vocal sound you're talking about, Rami. The trick is to not just compress the peaks but the whole track. Its not gentle, but because its also not just on the loud parts it doesn't stand out. Rock'n'roll, baby...
Other than the delay on the solo and the very last syllable of the lead vocal, the rest of the mix is bone dry. The squashed drum subs brought some of the room sound up in the mix, but I didn't feel like adding anything else. Kept it pretty raw- which seemed to be Rami's intent.
Take care,
Chris
