bouldersoundguy
Thats an interesting question. It doesnt sound the same if I experiment doing that on my DAW. A stereo mix , collapsed to mono, has elements of the stereo mix within its single source. And doesnt sound the same as a simply 'everything panned to center' mix and then collapsed to mono.
Interesting.
And for those wondering....NO, psycho-acoustics do NOT effect me....I perfectly capable of convincing me of anything.
This may be a case of what GONZO-X warned about. Practically all panning processes have some sort of pan law built into them. Without pan law a sound would get quieter when you panned it away from center. In ideal circumstances it would lose 6dB, but in the imperfect world of speakers it only loses around 3dB. To keep the level consistent when panning most pan controls boost the signal 3dB as you pan away from center. But that's 3dB less than would be the case for an ideal summing environment rather than an acoustic summing environment.
Summing your mix to mono is the "ideal" summing environment. You get the full 6dB gain on center panned sounds and no gain on hard panned sounds. The difference between that and simply panning everything to center (with its 3dB pan law) is that hard panned things in the summed-to-mono mix will be about 3dB quieter than hard panned things that are simply panned center.
