crazydoc
Master Baiter
OneRoomStudios said:crazydoc, Bob's mods...you guys agree? Is there anything else worth doing?
I would echo this - tube (because it's easy), then op amps and then input caps. This should get you the best bang for your buck.mshilarious said:Looking over this again, I see that Black Lion had resistor swaps and three caps removed. I have to say I didn't go that far, and it already sounds much better. Replace the electrolytic caps and bypass the caps on the input side (C12-15) with .1uf poly films. Swap the opamp for OPA2134. Change the tube if you like, and see where that gets you.
Record something really simple and repeatable, like a few guitar chords, before the change so you can A/B it.
You don't need to worry about bypassing the feedback resistors as the OPA2134 doesn't have the bandwidth of the LM6172 that he used. The spec sheet for the 2134 does however recommend bypassing the power suply pins with 10nF or greater caps. Also, you could put in sockets for the op amps - I don't think any miniscule stray capacitances that might introduce will affect this circuit.
usernamebob said:This all makes me wonder if other budget preamps can be modded in simpler ways to improve their sound, do many of these sort of pres have socketed op amps?.... how much difference would upgrading the op amps on units such as the dmp3 and the audio buddy make?
I don't know about modding the Audiobuddy or the DMP3 - thay are pretty clean as is. Naturally enough we're all looking for easy cheap mods to make our stuff sound like a million bucks - unfortunately, in most cases if it were easy or cheap, they would have built it that way in the first place.
But it's fun trying.
It would be a nice project to get this kit from PIAA (Tube Mic Preamp):
http://www.paia.com/tubestuf.htm
http://www.paia.com/fantusch.gif
and then mod it as you build it:
http://www.tapeop.com/magazine/bonus/paiamicpremods.html
