and , by the way, Mr.Poe sir,.. you are absolutely wrong about biasing,
Yes...and no. It really depends on the amp and the quality of tubes you are using. If an amp is well made...and I mean really well made...the the bias should be stable. If the tubes you are using are consistent, then biasing isn't really all that important. Let me give you an example...
I have a Fargen Bordeaux amp. Ben Fargen is as good an amp maker as there is. The amp came with 6L6GCs. Now if I remove those tubes and buy a new set of JJs or Svets or something else...I would agree that the amp will need baised. But that is because the tubes are all over the map as far as quality and consistency are concerned.
Now, here is the opposite end.
I take that same Fargen Bordeaux and set the amp up with a killer set of NOS RCA Blackplates (or equivalent). If I replace those tube with the same type of NOS tubes I normally don't have to do any biasing. This is just my experience. Good tubes don't fluctuate...new tubes do.
Biasing has become important because of the poor quality of new tubes. There isn't a tube made today that can stack up to an RCA Blackplate or a Tung-Sol 5881, or
a Mullard EL-34. Hell, even the Sylvanias/Phillips of the 80's are light years ahead of modern tubes. The Phillips 7581A is absolutely indestructable. trust me...I have tried..LOL!!!
Dr. Z makes an absolutely splendid amp. I know, I have owned several. Bogner and Rivera are also amazing. And an amp does need biased (and other things) if you are changing tube *types* (Ie 6L6 to 5881, or KT66, etc...). But in my experience, biasing is only necessary because we are using junk for power tubes and need to compensate. I have had a 1970 Marshall SL since 1980. I have never biased it, and it has never needed it. Of course I have only had to change tubes 3 times in 30+ years . Mullard XF1 EL-34s will do that to an amp. I also never had to bias my silver face Fender Twin.
There are a boatload of amp gurus who will tell you that certain amps actually sound better when the bias is slightly off.
You make several excellent points in your post. But I am of the opinion that a lot of biasing that is done is really not needed. Are there instances where it is important? Absolutely. But if you buy quality tubes and have an amp that is devoid of problems, biasing every 6 months is a waste of time and money. Put the money toward good tubes instead.
JMHO
