I agree with radiogold, to a point.
Let's talk about this for a while. This has nothing to do with green pens, which do absolutely nothing. And this is nothing obsurd, like claiming that one hard drive sounds better than another.
Jitter jitter jitter. It has been demonstrated that jitter can be burned onto a CD. It's copied to the disc via pit/land quality/spacing. Bear with me for a moment.
From a bob katz article:
"Any leakage current (interference) between the servo mechanism controlling the speed of the spinning disc and the crystal oscillator controlling the output of the buffer may unstabilize the crystal oscillator enough to add jitter to the clock signal. This does not change the data, by the way. If the servo is working harder to deal with a disc that has irregularly spaced pits or pits that are not clean, perhaps leakage from the servo power affects the crystal oscillator. It doesn't take much interference to alter a clock by a tiny amount."
And....
"Although the FIFO is supposed to eliminate all the jitter coming in, it doesn't seem to be doing an adequate job. One theory put forth by David Smith (of Sony Music) is that the crystal oscillator at the output of the FIFO is powered by the same power supply that powers the input of the FIFO. Thus, the variations in loading at the input to the FIFO are microcosmically transmitted to the output of the FIFO through the power supply. "
Ok, I'm glad you're still reading.
I believe that pit quality and spacing can introduce jitter into the signal. Pit quality dependant on the CD burner AND the media, pit spacing dependant on the burner alone (I'd assume).
Before you ask, pit spacing and quality certainly have an effect on the digital signal. In fact, it is the whole reason behind the eight to fourteen modulation (EMF) that audio CD's are burned with. Eight to fourteen recodes each byte to fourteen bits, lengthening pits and lands. The idea is to reduce the number of 0 to 1 and 1 to 0 transitions, minimizing the effects of small pits and lands and thereby minimizing the effects of jitter on the error rate.
But ok, let's forget about the jitter topic specifically and just talk about error rates. Every CD contains errors, most of which can be detected and corrected. However, poor media can result in a higher than tolerable error rate, and because of the "relatively" simple 2 dimensional parity error correction system of an *audio* CD, some errors could go undetected. Other errors might be detected but uncorrectable...in which case the sample is either dropped or interpolated.
If errors occur in a random fasion, you get white noise which is certainly audible. I think this is what most people expect when they think of errors in the digital realm...complete dropouts...static...etc.
However, if the errors are periodic, they might effect the sound in ways that are difficult to qualify. We know that jitter can be periodic and if jitter can be burned to disc then one CD might sound better than another, seemingly identical CD, depending on the burner. However we're interested in media quality in this thread....so I offer the following...
CDR's are inked and it is the quality of this initial inking that would have the most dramatic effect on the quality of the disc. Certainly the quality of the dye will be a factor...if the entire batch of dye is of poor quality, then it should result in somewhat uniform suckiness across the entire disc...random errors. I have a bunch of Memorx CDR's sitting here that are so bad, I burn one coaster out of three regardless of the burn speed. It must have something to do with either the dye, or perhaps the discs are slightly warped or something. But I digress.
Now if the concentration of dye has an effect, or the dye quality is extremely inconsistant, then this is where things get interesting. I'm just divulging here...I don't really know what I'm talking about...
If there is a "bad section of ink" on a disc due in some way to the some part of the manufacturing process, then we can safely assume that the error rate in the bad section of the disk will be higher than the good sections. Now here's the clutch. The disc spins. Duh. But this means that these sections of bad errors will occur PERIODICALLY during playback, thereby potentially damaging the sound not with white noise, but by changing the sound in a more subjective fashion (nothing should be subjective, but some things are hard to measure).
Certainly some companies have tighter quality assurance than other companies. This is true for every industry. Therefore, CDR's from company A might sound worse than CDR's from company B. This difference may vary over time.
This is all speculation, but I'd advise people to not chalk this one up as green ink.
I suggest the reading of the following articles:
http://www.digido.com/jitteressay.html
http://www.ee.washington.edu/conselec/CE/kuhn/cdaudio2/95x7.htm
Slackmaster 2000
