M
Micter
No Title
I had (well still have) a pair of Carvin CM90e's laying around. Basically they were just about worthless in their stock state. I started looking at the capsule housing and noticed the cloth around the inside of the housing. Got rid of that junk. I also noticed the foam in front of the capsule. That can't be good! See ya! Then I tested the mic and noticed it sounded like it was more open than before but had a wierd resonance. So, I look at the capsule housing again remembering that the capsule is set too far back and decided to chop off the capsule housing by about 1/2". I pulled out the grill material all the way around. I pulled out my trusty dremel with a cut off wheel and chopped off the last ring. (there are 5 rings on the stock units) Then I take them to the disk sander and straighten everything up. I used the two rings as a guide to shorten the screens (both side screens and the front grill) I glued the front grill in place flush with the capsule housing and re-installed the wire mesh on the sides. Now the capsule sits about 1/8" from the tip of the housing. The mics are very usable now. Funny how just some simple things that didn't even cost any money can make a junk mic usable.
I need to get some batteries for my camera so I don't have any pics.
"DO NOT TRY THIS IF YOU AREN"T MECHANICALLY INCLINED"
http://www.carvinguitars.com/manuals/CM90E.pdf
here's a spec sheet of the stock mic for reference
