I am trying to get something recorded. It is not happening AND I AM FURIOUS. I purchased Cakewalk Power and there is no troubleshooting section or anything!!
The same setup I am using records in Cool Edit Pro without a
problem. I am trying to record via midi using my MPC2000 as master. I have tried also recording via audio and am getting NOTHING. HELP!!
I have an EWS88MT soundcard. Under Options>>Midi Devices is the following:
Input Ports:EWS88MT Midi
Output Ports:EWS88MT Midi
Midi Mapper
Microsoft GS Wavetable SW Synth
Under both Input & Output Ports, both have EWS88MT Midi higlighted. EWS88MT midi is at the top for both midi in and out and they are both highlighted.
To top it all off: I can arm Track 1 for midi. Wait for it to say Waiting for 30... Hit play on my MPC2000 and Cakewalk says Chasing and continues. The problem is:
No midi data is recorded in Track One. Unless I should see a blank track. I don't know, never used Pro Audio before. Only Cool Edit. I even patched a module into my patcbay, which is patched into Audio In 1&2 on my EWS88MT breakout box. Played the mpc whilst arming Cakewalk for an Audio track AND I got nothing. I have done the same using CEP 2.0 and it works fine. Aaarggh!
Midi Mapper
