assin said:
anthony thanks for your help as you see I dont know what I,am doing....I,know about the 60cycle hum now I,am just trying to record one song from a music (CD)if I,can do this maybe I can go futher any suggestions will be taken very seriously
Well, one thing is very indicative if residential noise is from present system/driver mess combination.
Take any quality hi-fi source, CD/DVD, FM tuner if you will (provided with decent signal) and connect to your Sound Baster’s > I N <
Now, also prepare some recorded file wav or any other file -make it available.
What do you hear from IN's, is the signal OK? (should be as best as SB can deliver)
Now play prepared (old) wav and listen is it noisy as hell , as you mentioned earlier?
Now record this present input sound and play back this new recorded sound. Is this one also noisy or not?
If so, then it is a driver/setup related, behave as I have recommended in the first post.
If your sound is both as monitor , playback and recorded clean and without noise then this is in nowhere related to deficiency of your sound but CD recorder alone.
Borrow from your friend other CDRW or DVDR drive and reassure your self with this.
In either way, this problems requires patience and deductive logical way of reducing components to zero
and then adding one by one to see when the nature of
this problem presents its potential cause.
