musicmachine
I believe there is a thread here somewhere about using more than one USB recording interface at the same time but I can't seem to find it. Anybody seen it or know the answer?
Actually my question should be can you record using both interfaces at the same time. Say you have (2) two channel interfaces. Would you be able to record using all 4 channels? Sorry but I can't actually test it on my gear until tomorrow.On mac you can use two interfaces of any kind together.
I imagine there are exceptions, but yeah, that's how it works.
Are you using a Windows machine? from my experience I have found this is not possible because Windows only allows for one set of ASIO drivers to be enabled at once.
Yes, you can do this on your macbook.
All you have to do is go into utilities (shift-apple-U in finder), Audio/Midi setup.
Create a new device by clicking the little plus sign. It'll be called aggregate device.
Now click on it, and select your two interfaces with the check boxes.
The aggregate is a virtual interface that encapsulates your two real interfaces.
Finally, in your audio recording software, select aggregate device as your hardware.
You might have to setup your default outputs again, but see how you go.
