Ok, I am pretty sure I got the dropbox thing figured out (look out tone thread, here I come...). I spent a little time this evening recording a few of my little combos to give an idea of the clean channels of the amps for the OP. All were recorded with
an Audix i5 with a little time spent on trying to find the sweet spot on the speaker - considering it was a clean tone, I didn't spend too long messing around with mic placement. The i5 was generally more towards the edge of the speaker on all of the tracks. Guitar used was a Fender US strat, swamp ash body with texas special single-coil pickups - each track starts off on the neck pickup and switches to the bridge around halfway through the clip. Each amp had the EQ (when applicable) set to straight 12 o'clock, flat all the way across. Volume levels vary; I tried to get them just under where the amp starts to break up a little but may have flubbed on one or two. Nothing between the guitar and the amp except a 15' cable and no post processing.
Fender Blues Jr.
This is a modified Blues Jr, so it's kind of a party foul unless you want to buy a used one and put the $$ into it. It has had the BillM mods - bright cap removed, bias trim pot added, upgraded output transformer (NOS from the 60's) and a Eminence Cannabis Rex speaker installed. Tubes are all upgraded from stock as well.
Blues Jr. with "Fat" switch engaged
Vox AC15 C1 Normal Channel
My AC15 C1 is stock and loaded with the Celestion Greenback from the factory. Had no control over the EQ on this one; the EQ on the amp is only for the top boost channel.
AC15 C1 Top Boost Channel
Orange TH30 combo
This was my first thought in response to the OP. This amp does clean...and everything else. Takes pedals like a champ and can do everything from a whisper to a scream with ease. By far my favorite and my go-to amp for most anything. It's running the stock
Celestion Vintage 30 speaker; what more do ya need?
Marshall DSL40C
This amp does the clean to the dirty with ease BUT...as has been mentioned in other threads, it has a shared EQ section between the channels. If it's set for cleans it is hit-or-miss for the dirty and vice-versa. It's a fun amp to play on and if you're only recording with it then the shared EQ shouldn't matter that much. This one came loaded with a Celestion Creamback in it.
Ignore the crappy playing; I did a little percussive rhythm and little chording just as a short example...
Hoping that gives the OP something to consider.
