jamusic
Solved: Can Some Answer This: Is There An Option Missing In MIDI Port Set Up
Ok, so after re-reading the manual regarding setting up MIDI devices, it seems that the option to specify MIDI channels 1-16 is not there for my keyboards & sequencer inputs in the Devices>Setup>MIDI ports set up page.
The way it reads to me, there is supposed to be an additional option for this along side the 'In All MIDI', but there isn't. There's an empty bunch of slots next to it, and right or left clicking all around & everywhere does nothing.
Now matter what I try, nothing works, and the tracks all show the same MIDI activity as if I had clicked 'All MIDI'.
I do have the options for output channels on my MIDI devices & modules, but absolutely nothing for any incoming channels/devices.
So whether I play the keyboard, and use different MIDI channels, or send different MIDI tracks from my sequencer, the same thing happens - they all echo the same note on/off messages in all tracks as if just one track is playing to all of them - a.k.a OMNI mode.
To double check that this isn't my keyboards, I quickly opened Sonar, added a MIDI channel, and play the same keyboard without changing a single thing in either DAW.
Then I switched MIDI channels and it worked just as it should. Individual MIDI channels were available from 1-16 in the DAW as I changed them on the keyboard, where I can pick & choose any one of 16 in Sonar's MIDI track.
I have the OMNI option there as well.
In Cubase, it is operating in OMNI only [In 'All MIDI'], so something is definitely missing in the MIDI Ports Set up page.
I must admit I'm new to seeing 'Direct Music' & 'Windows MIDI', which are automatically displayed there - perhaps that's the problem.
According to the script in the 'Help button section', there should also be 'MIDI System'
as well, but there isn't.
Anyone else have this problem?
My devices: Yamaha P-200 Piano - MIDI Channels 1-16; Novation ReMote 37 SL - MIDI Channels 1-16 -[doubles as a MIDI interface]; Roland MC-50 Sequencer - MIDI Channels 1-16, TC Electronics SK48 Audio/MIDI Interface.
I'm not willing to believe that Cubase can't see or recognize 16 separate incoming MIDI Channels from common MIDI devices, [especially the Yamaha P-200 - hello!], so any help would be greatly appreciated, as I'm assuming there's something simple that I know not about in this DAW verses my other 2 that have no issues with this task.
My 3rd DAW - not a newb by any means other than just new to Cubase.
Thanks,
James
Thanks,
James
