Yeah, sure, but you need to tell us what you're plugging it in to.
If you're plugging into a line level, or instrument level, input then no - It's not going to work because there's no microphone preamp in the chain.
A microphone puts out a very low voltage signal compared to line or even instrument.
If you've got some gear with a 1/4 microphone input then that'll work.
Be aware that TS 1/4" is unbalanced and TRS 1/4" is balanced.
Your mic output will be balanced but your mic preamp, if you have one, may or may not be balanced.
The physical connector is simply that - It doesn't tell you about much about the capabilities or 'expectations' of the equipment.
That said, mic inputs are via XLR more than nine times out of ten on modern gear.
Tell us more, please.
