The tune is sounding cool man! I do hear what you are talking about with the placement of vocals in the mix. They seem not 'in it'. Good to hear you are not washing it in verb to make it fit. That rarely works...
My comments to come are just suggestions.
If it were me, I would first approach the vocal first with two compressors. One with a fast attack and 10:1 ratio. Then a second with a slow attack and less compression to smooth it a bit. Both only reducing gain like 3db at most.
Then for that particular voice I would suggest sending a bit of short slapback delay as well as a longer one. I also like to make the delay a bit 'low fi'. Pull the lows and highs out a but so it doesn't sound like it just a copy of the original track. Sometimes saturation/distortion can work really cool there as well to mask the delay so you more feel it than hear it. Plate reverb in there as a send as well. Maybe even a bit of a doubler would be cool in the background. All of these FX used lightly. It can get mushy really quick. I really just go for a layer of stuff behind the main vocal to 'thicken' it. That way it sits in the mix without having to be loud in the mix. It is a fine line to get that right. Sometimes, no effects are better. Just depends on the song and singer.
What DAW are you using?
If you have a few bucks, I would highly recommend Howard Benson Vocals Bundle. It $69 and well worth the money to have a bunch of easily placed tools in one plugin. I also use CLA Vocals which is only $29 now, but I find the HBV plugin much better and diverse for easy and broad ability to experiment.
I typically use other plugs for nailing down the vocals, but lately the HBV has been my go-to for quick satisfying vocal. Just finished a record with only two separate Waves API compressors and the HBV plugin. Turned out very nice.
