C
Cuzin B
All,
I am currently using a Soundcraft Spirit M12 analog mixer...an M-Audio Delta 1010 for my audio interface and Nuendo 3.x as my DAW.
How do I properly calibrate/gain stage each item to ensure that I achieve consistent levels within Nuendo?
I have collected a ton of tips in the past few days but not one has made it abundantly clear on how to do this. Here's what I have tried so far:
1. Load up a representative 1K sine wave tone (at -20dBFS) within Nuendo
2. Set master output bus on Soundcraft M12 to unity (0db)
3. Ensure the stereo strip on the M12 that is receiving the Delta outs (1+2) is also set to untiy (0db)
4. Run the tone and then adjust the input trim knob on this stereo strip to ensure this tone makes the M12 master VU meters sit at exactly the 0db mark
However when I try to calibrate to these tones using the process above - I end up having to turn my input trims on the M12 way past where the actual "0" marks is stencilled on the board. I would think that Soundcraft would have some reason why they would choose a specific point on the knob as zero.
Subsquently - when I run any audio file out of Nuendo - I get an unbearably hot signal coming back out of the Delta due to the extreme input gain setting.
Am I missing an important step something here? Do I need to open up the Delta software panel and make adjustments there? Like lowering my outputs etc?
Totally confused and looking for help!
Cheers!
Cuzin B
Cheers!
Cuzin B
