MercyfullMusic
My Sonar 1.0 is doing weird things.....
I have always used Sonar to record my band playing analog stuff, and played around a little bit with loops, never really done much MIDI stuff.
It has always worked pretty well so far until my current song I'm working on.
I decided to try to set up a MIDI track as a guide for me to record guitar tracks to and then have a drummer come in and replace those tracks. I have had to create 4 different tempos for changes in the song at different points, etc. for the first time. Everything seemed to be going okay until I went to start to mix and cut audio up, etc.
Now weird things are happening to my audio (not MIDI) sections. If I split an audio clip it it splits it in a totally different place and automatically deletes half of the clip! If I change the start time of an audio section it will skip way past where I asked for it to be and delete half of the clip! It also seems like sections I have recorded have now "moved" to different start times and I'm trying to put them back where they go.
I have opened new projects in Cakewalk and not had this problem so I'm thinking it's a setting I must have changed in this one project, that's why I thought maybe the MIDI or tempo changes were the problem. Does anyone have an idea as to what this could be?
Thanks.
Thanks.
