Thanks for the replies,
Roman,
No there is no hiss, etc. I can't say there is anything wrong with them, but then again I thought the Radio Shack cables were fine until I made my own and heard the difference (no hiss).
here is what I did right
- Heat up the cable end with the iron for a few secs then add a LITTLE solder just to make the cable end solid.
- Head up the connector end-point for a few secs, add the cable end to the heating process and add a little solder when the cable end is going to melt.
- wait until the solder get's solid
-voila
here is what I didn't do right
- ensure the surfaces are clean before you start by using isopropyl alcohol to clean them. (I just wiped with a clean cloth)
- when the joints are cool, clean them well with alcohol.
- I think I might have had the solder to hot because it just melted into the wire and connected it to the mettal. To look at the joints, the wire just looks silver (from the solder) and there is a little pool of solder around the connections. When I look at proffesionally made cables the solder seems to cover the wire so you see solder and not wire at the connection point.
The connections are very solid, and I have yet to have problems as far as that goes, I am just conerned if I could be loosing quality of signal because of the mistakes listed above.
If my mistakes only effect the longjevity of the cable I can live with that, but if I am loosing signal quality, I will redo them.
any opinions on this?
