Freudian Slip
OK. I had a thought. If I was to run a outboard pre and monitor it by running one of the pre's outputs into the insert jack using a TRS connector with no connection going to the ring of the trs plug, I could effectively bypass the boards preamp and have a different pre running through the channel strip.
Don't ask me why I would want to do it, but doesn't this sound as if it would work just fine given you don't exceed the max gain level that the strip can handle?
I'm just wondering if anyone has ever tried this or if there is a good reason that this is not possible?
Thanks
F.S.
Thanks
F.S.
