scarboro78
NYC HIP-HOP AMBASSADOR
Hey Guys! Long Time No Write..
I've got a question about bussing tracks in Cubase SX 2. I know for example in Pro Tools I can set the output of a track to go into a Bus Created with a Compression and EQ effect. Doing this sends the signal directly to the Bus instead of having an FX Insert which kind of creates a copy of the track with whatever effect you have it. (done through an Aux track in Pro Tools or a FX Track in Cubase). Using an FX insert I find sounds good on reverb and delay... But when using it for compression or EQ, it seems leaves the underlying track untouched kind of defeating the purpose.
My question is, is there a way in Cubase to route a signal to an 'FX Bus' and be able to route the buses to a master fader? I remember not being able to mix down to more than one Bus in the past, but I may be mistaken.
Thanks for your help!
