C
Craigory
My basement is currently in the rough stage and I am currently pulling wire for a project studio. I am mainly interested in building a vocal booth that can be used for acoustic guitar, strings maybe, and vocals.
I have framed the corner of the room to be about 5 X 6 X 7.5 high. Two sides are pour concrete. I would like it to be as sound-resistent (I will not use sound proof because I don't think I can on my budjet, and the house) as possible. Most of the time it will be used a vocal booth tracked by itself. I would just like a room with minimal bleed that will sound good.
One heating duct runs through the corner that I framed out. I plan on inslulating the hell out of it and sheet rocking with sound board as well. I also have a 2" PVC drain that runs through the room unforunetly and I don't know if i should frame it out or cover it.
What I have been told so far is that I should run my mic lines and headphone lines, insulate the walls, put up drywall, then soundboard, then drywall again (on both sides of the booth). I should then use some sort of a acoustical treament to keep reflections down.
My first question is, is this correct so far? Second, what are some suggestions for lights. I was planning on one air-tight recceseed light, but now I think I should maybe do a couple of wall lights, so that there aren't too many breaks in the walls. Third, how are the auralex wedges? Any other suggestions would be greatly appreciated.
It is definetly a permanent booth, and hell if I sell the house they can use is as a closet. Thanks for your help. I hope I was throrough enough.
I'm neck deep in a septic tank changeover!! F..........K. Never again.
Ever dug up one frederic. Don't. it SUCKS!!!!!!
