G
Good Friend
Hi. I want to try to build some mics but i need to know where i can get some mic parts like bodies and head/grill parts. Does anyone know where i could order some?
normalizer said:you could buy really cheap chinese mics and disasemble them. the only capsules i know of that you can get are electret condensers from digi-key or mouser.
Marik said:The best supplier is your local plumbing store. Here is a ribbon mic I made out of copper tube and coupler. The size of the coupler is a perfect fit for XLR connector. Just file a groove inside. The window I cut on a mill with rotary table and then turned on a lathe. You can use a hacksaw, as well.
PhilGood said:Mark,
B. Where do you get the wire cloth?
C. What screws are those on the side holding it together?
D. 2" pipe?
