pure.fusion
Hi all,
Good at engineering? I need your help.
In short, I want to cover a song in it's original key. Fundamental issue, I will not be able to sing in all the ranges need, both high and low.
In the past I have exported the backing, changed the sample rate, sung the part, then returned the samaple rates to acheive the goal but as you probably know this sounds quite fake for many reasons. I might add that changing to the next available sample rate in Coolpro is a massive jump in pitch.
What I need is to somehow drop the pitch by 2 or 3 semitones, sing the part then return to original pitch. The problem with this is that the pitch shifting removes all the quality and life out of the sound; just not usable. And before you ask, no I don't think I'm using quality pitch shifting software and I don't think I will be buying some any time soon. if only I could change the sample rate to the equivalent of 2 to 3 semitomes and not lose quality.
So, do you think I have any other options? Some other method perhaps?
Your thoughts?
Cheers,
FM
Your thoughts?
Cheers,
FM
