M
mattdee1
Active member
I have a Presonus Firebox, which has 4 inputs, and my bandmates and I were trying to figure out the best way to record drums under this limitation (upgrading to a unit with more inputs won’t happen for some time).
Those familiar with the Firebox know that only two of the inputs are pre-amped. We use our external Mackie board to pre-amp the other two. I know, I know… not optimal, but that’s what we’re stuck with for now.
We’ve basically agreed to allocate the inputs as follows:
- top of snare
- bottom of snare
- kick drum
- overhead
Both snare mics are 57’s, the overhead is some Apex large diaphragm condenser that my bass player has, and for the kick we will use an actual kick drum mic, which I assume is intended more for live applications (not even sure of the make, but certainly nothing high end). We plan to start by positioning the overhead about 3 feet above the cymbals, shifted slightly towards the ride cymbal side.
The LDC has a selector switch on its power supply that allows one to select the detection pattern (cardioid, figure 8, etc). Haven’t experimented much with that yet, but figured we’d start with cardioid.
I’m sure everybody has suggestions on what mics I should buy to get the best sound, and that’s fine, but what I’m really asking is for input from experienced people on where they would position their mics on a basic drumkit (only 2 rack toms, floor tom, ride, 2 crashes, snare, hi-hat) if they were limited to 4 inputs. Are we on the right track? Any tips would be greatly appreciated!
Oh, and not sure if this matters, but our sound is all over the place. It ranges from grungy 90’s Nirvana-type stuff to bluesy 70’s-rock-inspired stuff, with the odd shameless major-key pop tune thrown in to sweeten the pot.
Thanks
MattDee
- top of snare
- bottom of snare
- kick drum
- overhead
Thanks
MattDee
