HydrantC12
Hey..Just wondering what mic you can suggest for heavy hardcore/metal music. I have used the SM57..and im just not happy with it...especially when i record bassy breakdowns...My budget would be under 400$..thanks
chessrock said:What kind of amplifier are you using? And how are you getting your heavy guitar sound? Are you using a pedal, or are you cranking the gain on your amp?
Han said:btw, the JCM800 sounds bigger than the 900.
noisedude said:What pres are you using? I don't have much knowledge to add to this thread but from what I read you need a good preamp to make the best of that 57 ...
bgavin said:Look into an Audix D3 also.
It is specifically designed for very close micing at high SPL levels without overloading the preamp. The bottom end rolls off, so this will compensate for the close proximity effect. The D3 has an accurate, flat response, and goes up much higher than the SM57, and without the response peak.
