Ok... just found one at a music shop here and bought it used. Got it home and realized "oh it's all balanced input." All of my equipment is unbalanced. SO will I have to solder up some cables like RE said and tie the 2 leads together or what?
Yep, you will. It won't hurt the unit to use unbalanced but when I tried with it my Behringer, it caused a grounding problem that screwed up my stereo imaging and generated noise.
I have used my Composer in the unbalanced mode several times with no ill results. Just hook the damn thing up and use it.... If there is a problem, fix it then.
