mikemoritz
So this band I've been recording is done with the instrumental tracks, and I'm putting those all together. Problem is that the bass guitar is kind of inconsistent. The notes are all there, but the low notes are killing the mix because when I turn down the bass far enough so the low notes sit right, the rest is too quiet. I tried some compression, but still the low notes stand out pretty sorely. Any ideas? The problem range is right around 120-180hz. Would multiband compression work better? If so, what's the best way to work it (I actually tried it, but wound up more confused than when I started).
Hopin for help,
Mike
Hopin for help,
Mike
