Gtoboy
I would put a bit of saturation or even some harmonic distortion on the bass, it should help even out the sonics and allow it to poke through. A little low shelf might be called for around say 100Hz?
Bass isn't up in the mix at all.I had a go with the files.
Man, I'll slap that Jazz bass like a one legged prostitute that owes me money.- very hard. That kind of percussive rattle. So not a funky slap,but a Steve Harris bash!
You could just play it so the note doesn't sustain, either palm mute or bounce your fretting fingers to stop the note. You could also come up with a bass line the moves, so it doesn't do the exact thing the guitar is doing. There are lots of things you can do if getting the bass to cut is your goal. You could even change the guitar sounds so they aren't quite so nasal, then add some midrange to the bass.You think a dampener or bass mute might help? Cut the sustain off each note.
The opposite, I would say. The popping transients are way on top of any body or sustain to the notes.You think a dampener or bass mute might help? Cut the sustain off each note.
Taking ideas from the comments. I kept the beat and restarted. The more that i cut HPF or LPF , the better it sounded to me. No boomy bass in the guitars. It also sets everything back , like the instruments are farther away in the headphones.. i usually high pass guitars up to 170-200hz to make space for the bass.
Yes, I can.you play guitar as I recall right?
