strat0tele
I got a barcode and when put into my file the size given it seems to take up too much of the album cover. Is there a size that it should be or can I make it smaller? Is there a standard size that it HAS to be?
Bass40 said:Am I missing something or you dont suspose to put ya barcode on yourself.
strat0tele said:I have a file, i'm importing it onto my cover art......Whats so hard about that? All i'm asking is if it needs to stay the same size or can I make it smaller.
Rstiltskin said:check the size on current cd jewel cases, and you can always put it on the back, this is an assigned barcode, right, not one you just made up?
you need a manufacturers code or the use of someones, then an inventory number, i am assuming you did all this. barcode is one of the bigger problems getting into a national outlet, but a local store (like a recording of a highschool band at a local walmart.
quality is more important for a good read from a scanner. the barcode should be at least a quater inch high and good quality.
oh, did I mention quality?
strat0tele said:I did not make my own barcode. This is is a file I got from CDbaby for barcodes and it just seems rather large on my cd cover art compared to others, so I was wondering..........if I could make it smaller or does the thickness of the bars or however UPC works will matter.
TimOBrien said:Uh, did you think of the simple way??? Take a couple of commercial CDs down from your shelf and MEASURE them yourself!
"Always use the KISS method: (Keep It Simple...)"
