http://www.vandenhul.com/artpap/wiring.htm
Human nature is highly non-linear, and definitely
reluctant to let previously bad decisions die
– Examples: the RCA phono plug, XLR pin 1
• In the Bible it is written that the sins of the fathers
are visited unto the 3rd and 4th generations…
– In other words, we must live with design practices and
standards based upon bad technical decisions that are
sometimes many decades old
• NO amount of shielding seems to be effective!
Analog Signal Connections
• There are only two basic types of analog signal
connection:
• Unbalanced
– usually associated with consumer audio or very low
impedance applications (power amp outputs)
• Balanced
– usually associated with Pro-Audio and Broadcast
The Unbalanced Connection
• The signal is carried on one line and referenced to the
ground line or chassis connection
• Only the signal line has a specified source impedance
– The reason it is called “unbalanced”
Typical Unbalanced Circuit
• Signal is referenced to “ground” as it is perceived
by the local output and input circuits
– However there is usually ground potential differences
between the output and input circuits (Vcrap)
Ground Potential Differences Are
Often >1 mV
• With a 1 V audio signal and 1 mV of Vcrap the
typical S/N ratio of an unbalanced connection is
only 60 dB
– 300-1000 V signal levels would be needed to achieve a
S/N equal to the dynamic range of today’s converters!
• There are two significant sources of ground
Leakage Currents into Ground
• Leakage currents from AC Mains or other sources
can cause residual voltage potentials between the
chassis grounds of difference pieces of equipment
• Usually results from the capacitance between the
AC mains circuit and ground
– inter-winding capacitance of power transformers
– stray capacitance
– intentional capacitance (EMI filters)
The Ground Loop Problem
• If a ground loop exists, stray magnetic fields will
induce unwanted potentials in series with the ground
connection between any two pieces of equipment
– loop usually consists of the shields of interconnecting
cables and/or the earth safety grounding
The Simple Stereo Connection of
Two Unbalanced Cables Inherently
Creates a Ground Loop
• How the stereo cables are dressed significantly
affects the loop area
• Twisting stereo cables greatly reduces hum and
interference effects from stray magnetic fields
– Besides minimizing loop area, it also causes alternating loop
polarities
A Typical Setup has Many Loops
Basic Ways to Minimize Problems
with Unbalanced Connections
• Minimize the ground potential differences
in the first place
• Minimize the sensitivity of the circuit to
“Brute Force” Grounding
• Idea is to create a much lower impedance connection
so any potential differences caused by leakage
currents will be carried by a large, multi-strand cable
– think of the circuit as a current divider
– may increase magnetic induction problems due to creation of a
new loop (watch location of the strap versus the signal cables!)
Floating Unbalanced Source
• Requires a transformer or complex output stage design
– uncommon in consumer gear
• Removes the ground loop possibility, but signal is still
susceptible to other common mode influences
Quasi-Floating Input Design
• If the input unbalanced connector can be isolated
from ground, differential input design can give big
improvements
– Generally need HF bypass capacitor to prevent EMI
susceptibility problems (typ 10-100 nF)
– Also need some DC shunting resistance if source is
truly floating (typ 10-500 Ohms)
– Used in Audio Precision analyzers
• Quasi-floating outputs are also possible
The Balanced Connection
• The signal is transmitted using two signal lines having
equal source impedance (Zs).
– Voltage symmetry is NOT a requirement!
• The signal path does NOT
include ground
• Ground loops involving
cable shield do not affect
the differential signal
(in theory)
Typical Balanced Circuit
• Gives best possible immunity to ground potential
differences provided both source impedance and
input impedance are well balanced
– Cable construction is also a factor
Balancing Offers Vastly Improved
Rejection of Ground Potentials
• Typical component tolerances give 40-50 dB CMRR
without circuit trimming or matching
– Capacitive balancing is usually more difficult to achieveresulting in some loss of S/N performance above 2-10 kHz
• 60 dB S/N with an Unbalanced connection can easily
improve to 100-110 dB S/N with a Balanced circuit
having the same signal amplitude
The Grounded Balanced Source
• Examples
– Active balanced driver
– Transformer with grounded center-tap
• Symmetrical or equal
output voltages
• Ground loop in signal
path is not possible
– But the cable shield can be
part of other loops
The Floating Balanced Circuit
• No explicit ground reference--but it’s still there!
• Common mode capacitance is usually present
• Output voltage symmetry not assured
– measuring one side to ground gives spurious readings
• Ground loop in the signal path is not possible
– but the cable shield can be part of another ground loop
Interfacing Balanced Outputs to
Unbalanced Inputs
– No problem with
truly floating
sources
– Try using only 1/2
of the output with
grounded or ground
referenced sources
Interfacing Unbalanced Outputs to
Balanced Inputs
• Not a serious problem as long as the cable is balanced
and the input impedance greatly exceeds the source
impedance
– Cable capacitance imbalance will cause problems
Tip for Connecting an Unbalanced
Output to a Balanced Input
• Add a resistor equal to the source impedance in the
ground segment of the unbalanced output to create a
balanced output
• Voltage symmetry is not a requirement of balancing!
Testing for connection problems:
• Analyze noise spectrum
– requires a high dynamic-range FFT analyzer
• Try a “Brute Force Ground”
– use an additional, separate, better ground connection
• Use the 400 Hz High-Pass filter as a quick check
of improvement
– compare noise readings with and without filter
Noise Spectrum Analysis
• Will almost always show some AC mains frequency
• 2nd harmonic (100/120) can indicate full-wave or bridge
rectifier filter inadequacy
• 3rd harmonic (150/180)
caused by magnetic fields
• Higher frequency noise
and spurious spikes can
be created by motors and
lamp dimmers
Brute Force Ground
• Provide a very low resistance ground connection
between the devices and see if the problem is reduced.
– use #12 or #10 with many strands
THD+N or Noise vs. Hi-Pass Filter
• Compare Noise or THD+N readings in absolute units (V,
dBu, dBV, etc.) with and without 400 Hz high-pass filter
– An improvement of more than about 0.4 dB is usually an
indication of significant hum (AC mains related products)
The XLR Pin 1 Problem
• NEVER connect Pin 1 to the signal circuit ground or
circuit board ground plane
• ALWAYS connect Pin 1 directly to chassis ground at
both ends of cable
– use the lowest possible resistance and inductance
– leaving Pin 1 floating at either end of the cable invites
serious EMI problems
Summary
• High quality analog signal connection requires:
– (1) understanding of basic electronic principals
– (2) careful attention to detail
• High quality analog signal connection does not
happen by chance!
