Balanced Patch cables
  • Thread starter Thread starter itsme1234
itsme1234
itsme1234
Hi. I was wondering if there was a difference between quarter inch balanced audio cabled and balanced patch cables?
The patch cables seem to be cheaper, but they appear the same. The only main difference I can think of appearance wise is that the patch cables seem to generally be shorter...but I really dont need much length.
Any feedback is appreciated. Thanks!
I'm a little confused by your question. A balanced cable is a balanced cable.
A 1/4" balanced cable is Tip Sleeve Ring on both ends. They come in 3, 6, 9 12 etc lengths - whatever length you need.
A patch cable is another word for this cable. It patches (or connects) things together.
Thanks much ido!!!!
That's what i was looking for. I wasn't sure if there was a difference. Thanks again
And a balanced cable is a balanced cable. If you're using balanced I/O's, you'd best be using balanced cables. If you're NOT running balanced signals, you can still use balanced cables - but not the other way around.
Thanks massive. I don't understand why some listings refer to them as 'patch cables' and some 'audio cables'. I know it sounds silly but i just wanted to make sure the construction was the same and that patch cables weren't specifically meant for a patchbay. Lol
They typically get called patch cables when they are shorter in length, and with narrower connectors and for use in a patchbay or patching something on the back of a board, but they don't have to be used for those purposes.
