1st question:
I have an X V-Amp which has similar outputs as the V-Amp 2.
The stereo phones output is also a stereo line output.
The specifications say that this is a balanced output.
Does this means that I can connect it to a balanced input ( using a
stereo 1/4 connector to XLR connector ) and have a balanced signal
from the X V-Amp ?
If so, then the signal would be mono and not stereo ?
Can someone please explain ?
2nd question:
The digital processing on the V-Amp 2 and the X V-Amp is ( according to Behringer specifications ):
Converters: 24 bit Delta-Sigma, 64/128 oversampling
Sampling Rate: 31.250 kHz
DSP: 100 Mips
My question is: is the V-Amp 2 making 31.250 kHz samples of the guitar input for processing? Does this makes it less than CD ( 44.1 kHz ) quality ?
from the X V-Amp ?
2nd question:
DSP: 100 Mips
