Hey Mista Alt
Nice track, good work. This beat is good for a fast rap style with a true story to tell. Here are some things you should consider adding to your track which will improve it's sound.
The intro of the song needs some sound FX's that can bring out the mood and feeling of the piano. Fool around with some background sound FX's like ocean fx's, birds fx's, people talking etc... It really all depends on what kind of song it will be use for, if it's about someone that died that was a good friend. I would use sound fx's that you would hear in hospitals and also sirens, these ideas will give the listener a better picture of what your rapping about.
The piano sound in nice and was performed good, you should add a little reverd, so it don't sound dry.
The Orchestral brass sound is fine.
The string sound is fine also.
Kick and Snare drums are nice.
The lead analog sound that comes in on the right side of the speakers is nice, but you should consider adding a little delay so the sound can fade away. Not a dual delay that delays from side to side or left and right, but a delay that stays right were you have the sound pan at, Try using a Tempo delay
Bottom line: Just work on the intro, also what ever you do to the intro that you put in, also add to the parts of the beat were the same piano sound comes in, which is the brake/chorus.
Keep up the good work. Also what kind of gear are your using sounds like a Korg keyboard.
You can call me Ringo
Peace.
