vineband
nothing but a harp
I have the pleasure of having a client that has rented some really good gear for a week long vocal session we began today. We rented a Avalon 737 preamp (purple version) and a very old Telefunken U-47. Amazing overall... thank you God for an opportunity to use this stuff! I know it takes a while to learn gear and i was hoping some experience could push me along.
Here are some problems that i am having.
The mic is temperamental. There is some serious low hum that occurs every couple house that is remedied with a light wiggle of some cables and a tap on the body of the mic. This sort of thing happens in the course of a lifetime with electronic things so its seems OK, but needless to say i am nervous as hell. (yes i have great cables and plugged the thing in in the right order). Do old expensive mics just do random crazy things every once in while? After a few hours does the mic just need a rest?
The preamp sounds decent (not nearly as well as i was hoping... my $350 ARTstrip is a close 2nd). When metering the output the needle pretty much stays between the -20 to -10 mark max. Shouldn't i be reading much hotter than this. No variable (gain, output, compression, eq) seems to change the outcome. It sounds good. But i wonder if it should sound so much better than it does already. This preamp has seen better days... could it just be limp?
