You really don't gain anything beyond 256kbps, but I don't count this video as a real test because the computer sound will do sample rate conversion and processing from a web browser source.4 out of 6 and it was all just a guess.. Quiet surprising how little difference there really is...
The video here is just showing someone taking the test...The test is on NPR (here's a link to it) That is a legit test. Variables like what you are listening to it on will all have a impact on what you hear but the reality is normal earthlings can not really tell the difference.You really don't gain anything beyond 256kbps, but I don't count this video as a real test because the computer sound will do sample rate conversion and processing from a web browser source.
You tube comparison videos are sometimes bad because they will reprocess the audio. That is why some a/b tests don't work like the recorded audio when you play the video after uploading.
I disagree - while it wasn't a walk in the par - The Wav files were clearer with more presense/defintion in the lower frequencies and top end - and most of the time the midrange was a little harder to tell - but I could hear difference - now what I found interesting is they didn't ask which one sounded better - that being the biggest challenge - because some people like the sound of MP3s - while others like the sound of uncompressed audio.The video here is just showing someone taking the test...The test is on NPR (here's a link to it) That is a legit test. Variables like what you are listening to it on will all have a impact on what you hear but the reality is normal earthlings can not really tell the difference.
Seriously I know I am old and been through a LOT of loud noise in my life Going to a ton of CRAZY LOUD rock concerts, Playing hundreds of gigs in a rock band. Listening to music at home with speakers and with headphones too loud and lastly being in construction and using loud tools like tile saws, jack hammers etc....That I can hear and pass a hearing test and don't need hearing aids at 70 years old is a miracle...I do have tinnitus but I am used to it and just tune it out.I disagree - while it wasn't a walk in the par - The Wav files were clearer with more presense/defintion in the lower frequencies and top end - and most of the time the midrange was a little harder to tell - but I could hear difference - now what I found interesting is they didn't ask which one sounded better - that being the biggest challenge - because some people like the sound of MP3s - while others like the sound of uncompressed audio.
That's too bad - I've always worn Earplugs - and then Custom Fit Plugs - and the last 20 years I've used IEMs - very protective of my hearing - even when it's wasn't cool to do so.Seriously I know I am old and been through a LOT of loud noise in my life Going to a ton of CRAZY LOUD rock concerts, Playing hundreds of gigs in a rock band. Listening to music at home with speakers and with headphones too loud and lastly being in construction and using loud tools like tile saws, jack hammers etc....That I can hear and pass a hearing test and don't need hearing aids at 70 years old is a miracle...I do have tinnitus but I am used to it and just tune it out.
All that said I could not discern a significant difference between the audio files in the test. I listened and re listened and chose the one I thought ""might" be a little better sounding but for sure it was a guess... I got about 4 out of 6 right....Curious did you pick all 6 correctly?
I think it's more of testament to what people want to listen too - and that's music - how it's delivered is down the scale a few notches - very few people are practiced at hearing nuances in music - and even the lot of them have damaged ears but they can compensate - whether that's playing - engineering - or Producing.The results at NPR are that over 80% of the testers failed to discern the difference correctly, If you click on the graph below it will take you to the article about the results of the test.....If you are actually able to consistently discern the difference blindfolded then you are a unicorn in a herd of horses.
I remember someone telling me once that the NS10s were so bad that if you could actually make a mix sound good on them you had a winner. Lol.
