undergroundtoon
I have a Tascam FW-1082 that i am using as my sound card(On my current PC i have the internal sound on the motherboard unplugged). I am in the process of building another recording only pc. I was thinking of using a M-Audio 24/96 pci card in it, BUT when i record and playback i would not even use the 24/96(longer chain=more latency right?). Or will it connect to the coaxial in and out on the back of the 1082 into the 24/96(plus firewire). does this make the firewire just control the 1082 and computer(move a slider on one it moves on the other) making the in and out send and receive the audio you record. When you use a mixer, you use a line in and line out to a pci soundcard (as the same way a midi signal has in and out). I guess i never understood why i just used one firewire only. I thought In and Out was seprate so the signals do not cross? is my sound quality going to improve if i do this setup(if it even is one)? I am confused
and its not the first or last time.
