Attention DMP-3 Owners...
  • Thread starter Thread starter kidvybes
kidvybes
kidvybes
...there's a new thread over at Gearslutz.com (look under "New Product Alerts") describing a very effective modification of the popular DMP3 preamp...sound files are up as well...modifications can be done including transformer coupled output and re-racking in 1-U cases...a good little pre gets better!...very cool...look for the "DMP3 Mod" thread... ;)
Pretty neat. I just downloaded the files and played them together in my multitrack by crossfading in and out. Clearly the audio was improved. The modded track seemed to carry a bit more high end and felt ever so slightly richer overall. I also checked them both in the spectral analyzer and the modded track seems to have a fuller pattern.
If you ever get the inclination to stick an output transformer into a pre . . . don't. Put it in an external box instead, now you can route any of your preamps through the transformer box.
Tell me more... I always thought the "magic" was in the original conversion. Are you saying that you can take an electronically balance signal and impart the warmth of a transformer balanced signal at the output of the device?
...that might make an interesting product...kinda like a mini summing box...add a little "mojo" to your preamp...
...actually the guy doing the DMP3 mod also does some impressive mic mods...I auditioned an MXL V67 that he modded and the thing sounded golden!...sounded better than anything I've heard for 3 times the price...and he gives the mics a sweet paint job too...very cool...
http://jjaudiomic.com/
Transformers don't know or care if the signal they are getting is electronically balanced or not. They also don't know if their secondaries are generating a balanced or unbalanced output. Transformers live in their own world, referenced only to themselves. All they know is the difference in potential across their primary coils, and the source and load impedances on each of their coils.
The 'magic' in a transformer is a property of the transformer itself. It tends to be a function of the signal level; in other words, hit the transformer hard if you want it to saturate.
If we step back a bit in the history of the transformer and its modern application, we'll realize current techniques are a bit odd. Transformers originally were a part of audio gear because they were really needed for impedance matching (and of course excellent CMRR, which they still provide). Manufacturers strove to make their transformers as linear as possible, which since they had to cope with the hot levels required for tape recording meant really big, expensive transformers.
With modern solid-state gear, impedance conversion is not required. Also, transformer design has been raised to a high art by companies like Jensen. Operating levels can be far lower, because converters don't really want to see +20dBV, most clip internally at +6dBV or less, and have to have "pro" levels padded down to a level they can tolerate.
But still, the saturation that the designers of old and the modern masters try so hard to avoid is viewed at desirable. And so people need to push very hot levels into low-distortion transformers to get them to saturate, and then pad down the transformer's outputs back to a tolerable level.
To me, it makes a lot more sense to select a cheaper, smaller transformer that saturates easily and get the same effect at 0dBV . . .
The current issue of TapeOp has an article about this very thing, with input from Scott Hampton (of Hamptone.com). Very interesting.
Very, very cool... Thanks MS & tdukex
