Okay,
Just got done adjusting the brakes. They were off a bit. Up next is tension. ATR sounds Soooo good so far.
I can see how to do the first part of the tension alignment, (visually) adjusting the trimmer resistors so the idlers are correct.
Do you have a recommendation for the tentelometer wkrbee? It looks pretty easy in the manual. Not sure what to look for though in regard to that tool.
The following is a little off topic, but thought somebody might find interesting:
While adjusting bias and aligning the electronics so far, ATR doesn't seem to have a problem with noise or freq. response even down as far as +3 (250nWb) Pretty cool. You obviously aren't going to be able to push it into saturation but from my experience so far, my Tascam really wants to run at that level or the electronics start sounding glassy for lack of a better word. 3dB over at 10K seems to be the sweet spot on this machine, which appears to match ATR's recommendation, but I actually arrived at that after trying what someone else on the Electrical Audio forums incorrectly said was ATR's recommendation and finding bad frequency response.
But things might improve even more when I get the transport really dialed in. I haven't checked frequency response up above 16k, but the sound is really good as is.
I did some tests comparing ATR to SM911 and I think ATR sounds better. I biased for both formulas and correctly aligned the electronics, recorded the outputs of the same track to digital for comparison. I was using a song off my favorite album, Van Morrison's Astral Weeks for comparison. I first did a comparison at the exact same level, then I did a comparison where I started at the same reasonable level, then I gradually increased the level going into the tape machine to see how both formulas reacted.
Yes, there is noticeable tape saturation available with SM911, and seemingly none with ATR (at these low levels) ATR just gets louder and retains it's representation of transients beautifully. I don't really care for SM911, now, after having used it for a few years. I like 456 a lot, (wish is was still around. I didn't include it in this comparison) but there is something that seems a little poky or aggravated about the high mids of SM911. I can see some people liking it for that reason. ATR sounded wider and had a more ampexy top end I thought after this comparison. Though you can't make it sound like when slamming 456, it sure is elegant sounding.
