heinz is right, you have to physically position your cards, as IRQ's are assigned by physical placement on the bus. Some BIOS's will have options for assigning IRQ's to specific slots, but it's not usually a very straight-forward process.
Your motherboard manual should have some information about your bus, including which slots share resources with eachother and other devices on the bus (like onboard IDE and ATA controllers). If you put your card in a slot that does not share resources with any existing components, you're set.
Note, most devices are pretty good about sharing resources, even soundcards. IRQ's are really blamed way too often. Make sure you have a problem before you go creating problems.
P.S., if your soundcard is sharing IRQ 5, then you are not using ACPI so there is no reason to disable ACPI. Under the ACPI model, all devices will be assigned IRQ 9.
Slackmaster 2000
