waynefal84
I know this has probably been brought up by someone else and, if so, sorry for annoying you with a new "duplicate" thread. I've been having problems using the ASIO4ALL driver and after several hours of research I still haven't found a solution that works for me.
First, I'll tell you what I'm working with:
PC -
HP Pavilion - 1TB HDD - 8GB RAM - Windows 7 (64 bit)
Soundcard / Recording device-
Focusrite Saffire Pro 24
DAW-
Image-Line FL Studio 11
Doing some research on and off for the past couple months has not helped very much. The few solutions that were offered didn't fix my problem. For a while, I was able to use my DAW with no problem. Eventually it started freezing in mid-session and I ended up having to restart my computer every time this happened and it gradually got worse from there. After a few of those incidents my computer would completely freeze any time I tried to open FL Studio. Thinking it might be a registry problem, I decided to reformat my hard drive and start fresh. Then I reinstalled FL, Saffire Mix Control and ASIO4ALL, went into my computer's audio options and disabled the "Exclusive Mode" and it worked just fine (that was 3 days ago). Today, I installed Guitar Rig 5 Pro and attempted to try it out but I couldn't get any audio through either that OR FL Studio. The ASIO control panel tells me that the output is being used by another application. Keep in mind that I already disabled "Exclusive Mode" in all instances as described in every forum thread about this particular problem. I'm glad that seems to work for everybody else but I guess I'm not so lucky. Thinking back, I remember installing a demo of GR5 at one point (before the first meltdown) and that now has me suspicious of Guitar Rig itself. Maybe that is somehow the problem. And no, I did not have both FL and GR open at the same time. Please help.
Thank you for reading and I hope someone can figure this out.
PC -
DAW-
