I just mounted my AT2020 in the SP01 I have. Yes indeed it will turn, is just slightly loose, and maybe could rattle a bit. Out of a piece of rubber or cork, cut a circle slightly larger than the mics base and then a hole in the center to put the mic screw part through. This will take up the slop and shim so it's tight.
The SP-01 is designed and built by and for Samson mics, not Audio Technica's. The SP-01 is a popular inexpensive alternative for other non-Samson mics that come close to fitting such as the AT2020. Surprisingly the same thread as Samson mics. It does work quite well on the mics I've used it with.
If you can steer me to a vendor that can sell the Rycote for less than 24 bucks I'll gladly pick one up.
Samson SP01 Shock Mount SASP01
Rycote InVision USM-VB Universal Microphone Shock-Mount 044912
You get what you pay for - the Rycote is incredibly cheap compared to the top-end Neumann and similar shockmounts and is actually better.
If you go really downmarket and buy something extremely cheap - then don't expect it to perform like a better unit on a mic. that it was not designed for.
But, I did suggest the cheap fix for you in my earlier post.
O u c h ! !If you go really downmarket and buy something extremely cheap - then don't expect it to perform like a better unit on a mic. that it was not designed for.
More than often "home recording" equates to "recording on a budget".
To me "home recording" means recording because you love doing it. It does not necessarily mean "recording on a budget", but does normally mean wanting to spend money wisely.
It came as something of a revelation when I joined HR to discover that there are some professionals that operate from home in the audio world. But in broad terms, that definition is certainly what it means to me.To me "home recording" means recording because you love doing it.
