evm1024
Hi All,
I should be getting a pair of APEX 205 ribbons for Christmas. With that in mind I have some Lundhal transformers coming in the mail and plan on doing the well documented transformer upgrade as well as the pull the wind screens off mod which is also well documented.
However, ribbon re-tensioning is not so well documented. I don't expect to need to retension the ribbons but I may need to. And I may replace the ribbons at some time in the future.
There is some documentation of the procedure to deal with the ribbon without tearing.
The question is how to set the ribbon tension correctly and what tension to set this specific ribbon to.
From my reading it appears that the tension sets the resonate frequency of the ribbon and that a specific freq will tell you that the ribbon is set right.
I'm speculating that one could play some pink noise and then look at a FFT of the output of the mic to see the resonance peak. Is this the way high level mic modders do it? Is there another way?
Regards, Ethan
Regards, Ethan
