HomeMadeHitShow
Member
Another question
I am recording MIDI using a MicroKorg through an M-audio interface to a PC using ACID to record.
I have found that when I try and record using anything other than standard MIDI I get a slight delay, I can understand this.
However when I record using standard MIDI and then switch to a SFZ sound fount or other software syth I find the key hit are slightly late, even though they are on time using the standard MIDI sounds.
I can fix this by moving the file slightly earlier to sync up but if for some reason I go back to standard MIDI then I end up out of time again ?
Any thoughts on this would be great ?
Thanks again.
Tony
Thanks again.
Tony
