Ghostnotes
I'm getting ready to purchase some auralex to treat my very amateur drum room. My problem is that i have too much high range and a ton of reflection which combined is what i "think" is causing a very airy sound on playback. Tried different mic placements,eliminating my overheads and other experiments but in the end it just seems to be the room.
I'm thinking of either getting 1 or 2 roominator kits due to the size of the room and want to make sure that 1 or 2 will be enough.
The dimensions of the room are 12x20 with 8' ceiling. The drumset is facing longways with windows behind me and to one side but they are covered with very heavy drapes.On the other end of the room the ceiling tapers down starting just past mid-length to about four feet high in which I'm guessing does not help much with berber carpeting.
I'm not looking to make it sound perfect but just looking for some good pointers on how much i should use and what kind of placement i should use for starters.
If you need pics let me know
Thanks
Thanks
