Realistically, no.
In practice, it depends how good you are at writing firmware for microcontrollers and reverse-engineering serial data. The remote uses a couple of Panasonic MN17541 4-bit microcontrollers, which appear to be factory-programmed since I can't see any ROM on the board. The AKAI is probably similar - though if it has an EPROM you could possibly reprogram it to use the Fostex R8 protocol if you know someone good at that kind of thing. (Seriously, there are people who make custom ROMS for old hardware, e.g. the Cheetah MS6).
Probably your best bet would be to use an Arduino or similar processor to sit between the two machines and act as translator. However, you would need to reverse-engineer both protocols.
Ah ha. Okay
I really don't know how these things work. I was thinking maybe each of the pins on the DIN connector were wired to each function button. I guess it;s not a easy as replacing the 12 pin din on the fostex with an 8 pin for the akai and wiring up to the functions. I opened it up, but the wires coming off the cable are not labeled on the curcuit board to which functions they control.
Oh well...only $10 spent.
Here is the original Akai RC-X3 Remote Control Unit.
View attachment 99357View attachment 99358View attachment 99359
The lead is actually 4m long. When I first got this it did not work and all I had to do was re-solder some wires and everything worked nicely.
Here is the inside view..
View attachment 99360View attachment 99361View attachment 99362View attachment 99363View attachment 99367View attachment 99366
Here is the wiring diagram I found....
View attachment 99364View attachment 99365
It seems pretty easy to actually make your own with a few buttons. The wiring diagram shows which pins activate each function.
There are absolutely no electronics in the remote, just buttons.
I would imagine you could go into Fostex R8 remote and solder wires from the buttons to a cable with a din plug on the end.
Hope this helps.
I also actually have the Akai Remote Control Receiver - RC-X9R but not the transmitter. I cant find a transmitter anywhere on earth!
Must be rare I guess.
View attachment 99370View attachment 99371
Hi J
This will help you.
This is the wiring diagram of the actual 8 pin plug. Note that pin 7 is not used.
The stop function connects pin 5 & 6 to the sleeve shield wire so use a double gang momentary button for this (I think this is the right term).
Personally I would try and use the same type of cable with shield and 7 wire
The way you see me hold the Din plug away from the circuit board is the right orientation.
Well done!
Have you tried the record function? It only uses one button so the operation of pausing is by the same button. I guess the Akai just alternates the command with each press, try it.
When you press the RECORD/PAUSE button it puts it into record standby mode.
Then when you press PLAY the recording starts.
If you press the RECORD/PAUSE button again it pauses but in order to continue to record you actually press the PLAY button again and it resumes recording.
When you press STOP it stops recording or takes it out of record standby mode.
So the only way to actually record is by pressing the RECORD button then the PLAY button.
Try it.
