Well, here's my reaction. How good are you with a soldering iron and multimeter? Because almost certainly, it will need some attention somewhere. You don't have a power supply, and that connector has many pins, so it probably has multiple voltages (+/-15V, 48V, 1.5V, probably more; just guesses there).
Constructing a power supply is possible, but a significant project. Without the service manual or a schematic, it's going to be tough. So your first project is finding a service manual.
But before that, I would open the console and see what a channel strip looks like. If it uses 1980 vintage IC opamps, I wouldn't bother; for the time and expensive you could buy a good modern IC mixer like an A&H and come out way ahead. Put it up on eBay and put the proceeds towards a functional unit.
If the channel strips are discrete, it might be worth salvaging. If the mixer otherwise needs work, it might be worth pulling the channel strips and racking them individually (replace the faders with a pot).
Another fun project might be to strip the VU meters and build a meter bridge for whatever else you end up with.
As far as taking it to a shop, some shops will have a minimum bench charge for simply opening the thing up. That could be $100 or so. But maybe you'll find some old tech nostalgic for this bit of gear that would help you out.
